Baffle broke in catalytic converter
99 5.3L Reg cab
I posted a while back on a rattle and soem1 suggested I hit the cat with a mallet to see if it rattles... and if so.... problem identified. I did this and sure enough.... its a baffle broken in there! :thumbs:
How much will it cost for a replacement converter (aftermarket, high flow)? What about getting O2 simulators and just having that cat replaced with pipe? What do those simulators run?
Original Factory from dealer is about $550. I think I seen them on GM Parts Direct for around $380.
Both cats come as one piece already welded into the y-pipe. I believe the cost is complete with the 4 new O2 sensors.
check under federal warenty emisions parts some are covered for
longer than gm standerd 3/36000. cant hurt to ask just might save you
some $$$$ :crazy:
99 5.3L Reg cab
I posted a while back on a rattle and soem1 suggested I hit the cat with a mallet to see if it rattles... and if so.... problem identified. I did this and sure enough.... its a baffle broken in there! :crazy:
What does the rattle sound like?
My driver side on my 2000 makes a metallic rattle.. If I hit the CAT (COLD OF COURSE ;) )
With my fist I can hear the noise... I was almost committed to replacing the cat when I realized the noise is coming from the d**n O2 sensor.. There is a little metal ring around the end of it where the wires come out.. The rattle is the metal ring.. Check that 1st...
Chuckster - I am trying to find a rattle from under my truck - when did yours occur?
I just bought the truck 2 months ago... Its a 2001 Tahoe.
I noticed the sound when it's idling in the driveway.. drove me nuts till I crawled under there and found it..
