weatherstripping under front doors?
does anyone have weatherstripping under their front doors? I am watching a video on how our trucks are made and I seen them add weatherstripping to the bottom of the front doors. Mine doesnt have this and was wondering if you guys had it
My 89 didn't have it, my 97 did have it and my 04 doesn't have it. I dont like it because it makes it hard to clean the sand and salt from the underside of the door. It even seems to hold the sand in. The 89 didn't rust but the 97 started to rust in this area. My 2 cents.
I have to agree with builderpaul, My 01 & 04 dont have the seal and its easier to clean. I only powerwash my vehicles and it cleans everwhere even behind the door edges. :crazy:
Yep, my '03 Silverado Ext. Cab has a black rubber weather strip along the bottom edge of the door. It's right along the inside of the bottom door flange so it can't be seen from the outside.
Yep, checked my 03, I have one too....
I have never had a problem with cleaning so far. I will have to pay a little closer attention to see if it holds dirt there....
Yes I have it :thumbs: It's a PITA to keep it even halfway clean when you spend as much time in and around dirt and sand as I do.
hey wingnut could you possibly take a pic when you have a chance? I wonder why my truck doesnt have it???
Sure, but it will be about 1 a.m. (CST) before I can post it. I'm at work.
The pic will even show how it collects crap, as I had a lot of fun this past weekend. Got a little dirty. :thumbs:
seadoons heres a copy of it. Just a warning but its like a 32 min video.
http://www.silveradoss.com/videos/FT-PlantTour.wmv
G7 thanks for the photo. My truck does not have that. I found it odd that when building the trucks they were putting them on and mine doesnt have it along with others I have seen. Maybe on the newer trucks they put them on?
Ryan,
This is an awesome video! Where did you find it? I have always wanted to go to a plant to watch how they are made, but this video has satisfied me for a while. I don't know if you noticed this or not, but at 29:32 on the video time, the guy is out doing a test drive on one of the new trucks, and he has it up to 100 MPH. :thumbs: The speedo also goes up to like 180. What kind of truck is this?!?!?! It just now hit me that maybe it is 180 Kilometers? d**n!!!!
Thanks again!
that truck was in canada and the cluster was in km/hr
That is what I thought! I washed my truck tonight and made a point to look under to doors and I do have the weather stripping under the doors, but the front and the extended cab door.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
