Front Axle Seal?
Gentlemen, I have a '01 Silverado, X-Cab, Sportside, 4x4, 5.3L. I've noticed my drivers side axle seal weeping oil. How much of a Bit__ is this to change? I've noticed an article named "CV Axle Nut" & was wondering if they were talking about the same animal? Any help will be greatly appreciated :wtf:
the axle nut has nothing to do with the axle seal
but make sure it's not the ven't plug leaking first
the vent is right above the left axle seal
if the vent is black it's not compatible with synthetic fluid
a synthetic compatible ventplug is white
as for the axle seal the driver side is the easier one but
if the axle is stuck int he diff it can be a super pain
I second that :wtf: Just did mine on Fri....had to pull the carrier out so I could get a slide hammer on it...still took awhile :chevy::mad::cry:
Just did this on the neighbors truck. The vent was the culprit...Of course, if we had figured this out before we changed out the axle seal, it would have saved a bit of time. :wtf:
The axle seal (drivers side) shouldn't take more than an hour or so to do, and isn't all that difficult. An impact hammer makes the removal of the axle much, much easier, so if you have access to one, grab it.
