ECM-B fuse keeps blowing!
Here is the deal:
96 Z71 ECSB. 146k miles.
Friday it worked all day long and into the night no problems. Saturday morning (while taking a friend to the airport no less), we start up the truck at her home, and leave for the airport. We decide to stop to get something to eat. No biggy. Just a short stop. Get food, get back in the truck, and it'll crank forever, but it won't start.
I call a buddy of mine, and he tells me to check if there is fuel pressure. Nope. None. So eventually, my other friend tows it home for me. I assume it MUST be the fuel pump, because you can't even hear it running when you turn the key. I "Thought" I checked all the fuses, but I guess I didn't. Anyway, Sunday I replaced the fuel pump, thinking that was the problem. I get it all back together, and try to start it up. No bueno. So I check the fuses again. Sure enough, a burnt ECM-B fuse.
I replace it, and the fuel pump relay with it. I start it up, and of course, it has to pressurize, so it takes a minute, but it starts. WOOHOO! I turn it off and go inside to clean up and change. I come back outside, and try to start it, and it won't turn over. I check the ECM-B fuse again, and it's blown. AGAIN! :lol:
I'm pissed at this point. :smash: I have no idea what to check. The fuel pump is brand new. The sender, all the wiring coming out of the tank, and everything else in the tank is new as of about a year ago. When I pulled it apart, it looked brand new. Why is this fuse blowing? How do I fix this??? I really wanted to go to the lake today, but that's kinda out of the picture I think. I searched for a few minutes for this fuse, and it sounds like this is a normal problem, but I couldn't get a difinitive answer. Please help me!
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
