NOPI NATIONALS Show Series - Bristol TN July 10-11
NOPIMAN
NOPI NATIONALS Show Series - Bristol Motor Speedway, Bristol, TN. July 10-11
NOPI return to Bristol with their Truck Dominated event!
All Truckers are Invited!!! Separate Truck Division in the Car Show.
Truck Classes for Bristol Event are:
T100 Truck - Mini - Ford 2WD - Conservative
T110 Truck - Mini - Ford 2WD - Mild
T120 Truck - Mini - Nissan 2WD - Conservative
T130 Truck - Mini - Nissan 2WD - Mild
T140 Truck - Mini - Toyota 2WD - Conservative
T150 Truck - Mini - Toyota 2WD - Mild
T160 Truck - Mini - Dodge 2WD - Conservative
T170 Truck - Mini - Dodge 2WD - Mild
T180 Truck - Mini - Mazda 2WD - Conservative
T190 Truck - Mini - Mazda 2WD - Mild
T200 Truck - Mini - GMC/Chevy 2WD Thru-93 - Conservative
T210 Truck - Mini - GMC/Chevy 2WD Thru-93 - Mild
T220 Truck - Mini - S10 2WD 94-up - Conservative
T230 Truck - Mini - S10 2WD 94-up - Mild
T240 Truck - Mini - Sonoma 2WD 94-up - Conservative
T250 Truck - Mini - Sonoma 2WD 94-up - Mild
T260 Truck - Mini - Other 2WD - Conservative
T270 Truck - Mini - Other 2WD - Mild
T280 Truck - Mini - All 4WD - Conservative
T290 Truck - Mini - All 4WD - Mild
T300 Truck - Mini - All - Wild
T310 Truck - Full Size - Ford/Lincoln - Conservative
T320 Truck - Full Size - Ford/Lincoln - Mild
T330 Truck - Full Size - Dodge - Conservative
T340 Truck - Full Size - Dodge - Mild
T350 Truck - Full Size - Chevy/GMC - Conservative
T360 Truck - Full Size - Chevy/GMC - Mild
T370 Truck - Full Size - Toyota/Nissan - Conservative
T380 Truck - Full Size - Toyota/Nissan - Mild
T390 Truck - Full Size - All - Wild
T400 SUV - Mini - Ford/Mercury - Conservative
T410 SUV - Mini - Ford/Mercury - Mild
T420 SUV - Mini - Chrysler/Dodge/Jeep - Conservative
T430 SUV - Mini - Chrysler/Dodge/Jeep - Mild
T440 SUV - Mini - Chevy/GMC - Conservative
T450 SUV - Mini - Chevy/GMC - Mild
T460 SUV - Mini - Other - Conservative
T470 SUV - Mini - Other - Mild
T480 SUV - Mini Van - Conservative
T490 SUV - Mini Van - Mild
T500 SUV - Mini - All - Wild
T600 SUV - Full Size - Chevy/GMC - Conservative
T610 SUV - Full Size - Chevy/GMC - Mild
T620 SUV - Full Size - Ford/Lincoln - Conservative
T630 SUV - Full Size - Ford/Lincoln - Mild
T640 SUV - Full Size - Other - Conservative
T650 SUV - Full Size - Other - Mild
T660 SUV - Full Size - All - Wild
T700 Truck/SUV - NOPI CHIC - Conservative
T710 Truck/SUV - NOPI CHIC - Mild
T800 Truck/SUV - All - Unfinished
T999 Truck/SUV - Best Of Show
All the Crazyness, NOPI TV and World Class Sport Compact Drag Racing.
Car Show - 5 big winners $600 each
Anyone can race. $4500 - 8 class Street car race. Open session all weekend.
All the details at NOPI.com
Anyone interested in going?
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
