transmission leak
I changed out the filter on my transmission about 3 months ago. I noticed a leak yesterday on my truck and when I checked underneath I saw transmission fluid forming a perfect drop on the end of my filter. I would like to think that the filter is not tight enough, but I can feel flud along the sides where the transmission bolts into the bell housing. If my filter was not tight enough could fluid spray along the bell housing??
Thx
Mick
I wouldnt think its SPRAYING,more like the drips being sprayed by air passing under the truck while you'r driving...just a guess
I have had the same problem with just a drop of tranny fluid on the bottom of the filter. I had this problem with the filter that was on the 2001 truck when I purchased it. I changed the fluid and filter at 4500 miles and I still get that drop of fluid on the bottom of the filter after driving 300-400 hundred miles. I wipe my hand around the filter and it doesn't feel oily. I have tighten the filter very tight and still get the drop. I've read that there is very high pressure at this filter. I never get any fluid to drop to the ground. Never seen a spot on the driveway. I posted this question before but never had anyone say they have had the same problem.
