Heated seat stopped working.
This past winter the drivers side heated seat in my Yukon stopped working. Anyone have any ideas?? I figured it is a good summer project to get it working again. How hard to work on it, I need to do a new seat cover on the seat bottom anyways, so maybe a good time?
First place I looked, fuses all good. I've been told the fine wires in the element, similar to wires in defroster, may break after being sat on for so long??? :banghead:
The heated seat element is actually pretty rugged. Only seen one bad element in the dozen or so seats that I've done.
What year is your truck?
You'll need to see if power is getting to the element, unfortunately there is no easy way to manage that test.
The cover comes fairly easily and the element is right there, so maybe you can start there.
The only other way is to hit the dealership up to diagnose it - they can hook up the ol' Tech2 and see the status of the seat, and whether or not the element is commanded on. - But then of course you gotta dish out the $$$.
I say try it yourself, we'll try to help you through any problems.
Hope this helps.
Truck is a '98. Your saying pull the cover off and test for power at the plug for the element. How are the seat covers held on, cause I actually am going to be replacing the lower cover. I don't imagine they still use hog rings, probably some fancy clip now???
They had a problem with those seat elements in those years. That's why the new ones are not as hot. Mabye someone with a service manual could e-mail you the test procedure. Sometimes you can ask a tech and they will print it out and even give you some tips. I've done it many times.
The cover ids held on by long strips of plastic J-channel. Just put a long screwdriver between the channel and the steel frame of the seat, and pry apart.
The back seam is hooked with 2 pieces of j channel (sort-of) and those too can be pried apart with a screwdriver.
Once you have that off, you should be able to locate the plug for the heating element pretty easily.
Since it is a '98 it is possible that the element is bad as Quadrasteer said above. I was thinking that your truck was newer than that.
It should be pretty simple to test, just push the heated seat button, and test at the connector for 12v power.
Hope this helps.
Thanks for the help guys, I'll test it out soon.
Intruder, are you sure the element is sewn right in, or is there just a pocket it slips into? My wife called while I was at work and got a price for the lower leather seat cover of $362 and a new element for $76. There was no mention of the element being sewn right in, and I would think they wouldn't have different part numbers??
NH............GM has had quite a few problems with the bun warmers
lately. Prob. another 3rd world quality part !
I see a LOT of failures posted in the Caddy forums !
My bun warmers failed in my 02 Caddy. They had to replace the entire
seat bottom. Pretty SPENDY too ! Good thing for warranty !
Call the Chevy customer 800#, have your vin# handy............
There might be a "silent" recall for your truck !
I called on my gf 96 Blazer and got the wiper motor (crummy circuit
board solder job) replaced FREE !
Dealer played stupid BTW. But were suprised when I rolled in with the
GM replacement id # and got it fixed ! ............geo
I only know what the dealer found out after a rather lengthy part search. I gave up on the heated seat as soon as it got warm out. I'll probably have to take the seat apart to confirm what they told me.
Please post back when you learn more.
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   1 Member, 0 Anonymous, 6,049 Guests (See full list)
    • I was around and remember that era very well, so I'm calling b/s on that statement. If they were that bad no police department or taxi company would've bought a single one ... but they were used in both services (and fire) for DECADES. They were bulletproof and proven. Even the early 21st century ones weren't too bad! The early models were legendary.   Mine is proof, but people like atlas are blinded by agenda and refuse to believe facts right before their very eyes.   Even decades after they were built, a new generation started driving them, posting all their builds and shenanigans on Grandmarq.net and Crownvic.net. The failures would show up then, since they all were deep past 100k-150k miles by that point, and younger drivers tend to be a little aggressive, especially with vehicles than can lay a one-tire fire for as long as you hold your foot in it. They've more than proven themselves over the decades.   The only thing that'll really take them out is road salt. The bodies and sheet metal were garbage. A victim of the cheapout FoMoCo and GM have been partaking in before then, and since.   Today it's the stuff that counts - the undercarriage that rots away first!    GMs Caprice was no slouch either. Reliable as a stone ax - the opposite of what they build now.
    • Let me know how your vehicles do in 10 years. You don't know ******, kid. 😂    There's a reason that Panther platform was used as police, fire, and taxi service for DECADES ... long before you were born, apparently.
    • If your connector also has a big lever to get the connector on and off, you don't want to force the lever either way, as it becomes a bigger problem if you bust the lever or the mechanism it works.
    • It's just useful to disconnect the battery to prevent odd shorting out when unplugging/plugging stuff together.  I also  touch the two cable ends together (after disonnecting) to drain the small amount of stored battery energy in various modules.   I believe the main system where you need to be more concerned with, so you need to do the above and then wait some time, iss when you are working on the air bag system, to prevent inadvertent firing of the air bags.   The in-cab switches are just that, plain switches, it's generally not a problem to swap them in/out.  For my '12, I'll get an error message on the dash if I power up the truck w them unplugged, but that's it (power up= turn the ignition on).   The ITBC located above the spare tire is a computer that manages the trailer brake system.  That is probably more important to have the battery disconnected.  It does have to be programmed to the truck, either before or after it's installed, for it to work.  For my '12, I had a very hard time reinstalling the main connector to it (IDK if yours is the same or not), it turned out the silicon seal was jamming up, preventing it from going on all the way.  I finally got it fully installed by lubing the seal with a bit of dielectric grease, then it slid on and latched in place easily.
    • JR ! I just got the truck back from the Dealership today . The technician did a cold remote start on the truck this morning and it made the noise . It was determined that it was a starter issue and replaced it under warranty . Of course   it did not make the sound after a new starter was put in because the truck was not cold . We will we see what happens tomorrow morning when I start the truck cold  . Keep tuned !   Oh I found a video on YouTube of a cold start and it did the same thing your truck and mine do , I will see if I can find it and post it up
