'99 Suburban cabin filters
Hello all. Can anybody tell me if a '99 Chevy Suburban has the cabin filters, and if so where they are? (1500, 4wd, dual a/c). The parts book at CarQuest showed it taking the same elements as my '01 Silverado. However I dropped the bottom off of the housing this morning, and found no filters, and could not see where any would go. (Helm manual on order). Thanks, Flinger.
NO,YOUR '99 SUBURBAN DOES NOT HAVE AN IN-CAB AIR FILTER.THEY ARE ONLY ON THE NEW STYLE 2000 AND UP TAHOE-SUBURBAN-YUKON SUV's AND '99 AND UP NEW STYLE PICKUPS.(PLEASE NOTE THAT IN 2000 GM MADE BOTH THE "OLD-STYLE" AND THE "NEW STYLE" SUV's)
Thanks. Not the first time a parts catalog has been wrong, eh? Just wish I'd known for sure before taking the lid off. Looks simple, but took me quite a while to get it back on. I'll be glad when the factory manual gets here. The 'burb still smells new inside anyway. ( 50K miles ) I plan on doing the '01 today.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
