Attn:MountaineerTom 99Z71
What did you use to clean the gears in your rear differential? Did you put any additives with the new gear lube? My truck has 4.10 gears with the locking differential and I am going to service mine this weekend (and clean the engine). Also, if you changed the front lube what did you use and any tips?I appreciate you posting those pictures, the timing was perfect for me. Thanks for your continued help.
y2kz71,
I just used some brake cleaner in a spray can that I had.  It worked really well and evaporated so I didn't have a bunch of fluid and junk left over.  Before I used it though, I sopped up as much oil as I could with a rag.  I didn't use any additives, just the Valvoline Synthetic.  From all that I've read, you don't have to use any additive with the synthetic oils.  It's working great.
I havn't done the front yet.  I have the oil, regualr Valvoline 75w-90 (or whatever weight the manual calls for, I can't remember it off the top of my head).  Here's a tip on refilling.  Again, I can't remember off the top of my head, but the manual says to refill it to within 1 5/8 to 5/8 of an inch from the BOTTOM of the fill hole.  I thought "how in the #### am I going to know when it's at that level?".  I measured the short end of a few allen wrench/hex key, or what ever else you may call it,  and found one that fell into that range and dipped it  into the hole, pumped oil in, and rechecked it with the allen wrench until it was up to the level it should be.
I was planning on doing it at the same time, but ran out of daylight and havn't got around to it yet.  It's my understanding that the front is as simple as drain it and refill it.  I have a Haynes manual, but havn't looked it up in there yet.  There is not cover on it though, which you may already know.
No problem for the pics.  Glad it helped someone.  I take it you seen my message over at the Pacific forum on cleaning the engine?  I think I posted a similar message here too, but can't remember.
Good luck and feel free to contact me for any more info.
(Edited by MountaineerTom 99Z71 at 9:16 pm on May 9, 2001)
Quote: from Stepside Z on 11:03 pm on May 9, 2001
Tom,
How many miles did you have on your truck when you changed the diff fluid?
Just over 22,000 miles.
Thanks Tom, I guess I know what Iwill be doing Sunday. Thats a good tip on using the allen wrench as a measuring device.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
