PREDATOR UNIT UPGRADE
Just got my Predator less than 2 weeks ago. :puke: I can tell the difference in power, but it never did what eveyone said it should do. :sigh: So I called Diablo Sport and spoke with a rep. They informed me that my unit needed upgrading. I have version 1.10 and they are up to 1.13. So out with the new program, back with the stock, and sending the unit in for for the upgrade and hopefully will see a difference.
Supposedly the fuel curve, timing, and most of all... the elimination of TQ MAN :puke: are all updated. Along with the shifting programs and ect....
WE WILL SEE NEXT FRIDAY :puke:
Oh yeah, I know it was performing better because it will now light up the 30" stock rubber where it would not even spin them over stock.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
