Electrical Upgrade, what sizes?
Wanting to know what size ya'll used when upgrading the BIG 3 under the hood. I am thinking of going all 0 gauge. (Wanting to upgrade alt as well) Do these come in standard lengths or did you guys "build" them using crimp on terminals? Thanks!
