Are Manual Transmissions noisy??
My manual tranny sounds like a semi when you are first starting out and I was wondering if this is normal. At low RPM it makes a crunching metal sound when going and and then stops at high RPM and when it's at about 2,000 RPM. Is this normal. It's really hard to describe the sound, but it's almost like when your tires start to move after they have been on painted concrete. It also clunks almost everytime when putting it reverse because it seems like the tranny is still spinning when I put it in gear. Is this a clutch problem? Are my syncros messed up? Someone told me the manual transmissions all sound like that. Is this true? It's a 98 4.3L.
Thanks,
Nate
Sounds normal to me.
My buddies have had the following trucks
93 GMC 1500 305 with a 5 speed
93 Chevy 1500 350 with a 5 speed
97 Chevy 1500 350 with a 5 speed
1st and 2nd were kinda noisy
The reverse thing sounds normal.
No worries! I´ve had a Ford 7.3 making a lot of gear noise and a GM 5.7. If you have more than 100k miles on it, its just probably the bearing in the clutch assy.
I wouldn´t stop sleeping over this.
Manuel
2000 Z71 ExCab LT
2003 2500 HD d-max
It's annoying but normal after some miles on the tranny. I had a '98 S-10 with that same engine/tranny setup. It made the exact same noise that you describe starting at about 50,000 miles. The service advisor at the dealer told me (after the tech drove it) that it is 'gear roll-over noise'. Whatever the heck that means. He said that as the tranny wears the tollerances between the gears get slightly larger and the tranny will get noisy. It does help to keep the fluid changed even though the owner's manual says it never needs changing. Don't worry though. The gears wont seize up on you or anything. It's not eating its self alive.
About the noise you get going into reverse. Check the owner's manual. I recall that mine stated that the clutch pedal needs to be depressed for approx 6 seconds before shifting into reverse to allow the gears to stop turning.
I'm having the same problem, mine started at about 70,000 miles. I have 160,000 miles on it now. To me it sounds like the input shaft bearing/bushing. Does anyone know where to get a rebuild kit for these? Advance auto sell a rebuilt tranny for around $500, but thats more than I want to spend. I'm looking to sell my truck & get an older (67-72) model. I don't want to put too much money into it.
    • Oh yes, someone is going to be certainly hitting up GM service/ support for a 20 year old truck.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
