Factory wheels
Does any one know of a way to reseal the clear coat on factory wheels. I have a 98 Yukon. when i replaced the tires the wheel weight left marks on the rims. I chip away the flaking clear coat and then took a small wire brush to the marks. It look good but now i want to seal it again. Will any clear coat spray paint work???
you can use model paint ( acrylic enamel oil based) depending on how big the spot is. You can apply it from the small jar using a model brush ( fan tip ) or you can by the Clear top coat in a spray can. I used the model spay on some aftermarket wheels and it worked good. The model spray has a finer spray :thumbs: than the big cans. Just mask off the rest of the tire/wheel and take your time. once you have finished and it is dry, some 0000 (super fine) steel wool will remove any runs or blemishes. Then clean it and give it a look. :smash:
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
