FRONT DIFFERENTIAL
HI, I HAVE A 2003 GMC ENVOY SLT AND I HAD A LEAKING FRONT DIFFRENTIAL. FINALLY AFTER THREE VISITS TO DEALER,THEY REPLACED WITH A BRAND NEW UNIT.I HAVE A GOOD FRIEND WITH SAME TRUCK,AND HE IS GOING TO DEALER ON MONDAY FOR THE SAME PROBLEM.ANYBODY ELSE HAVE THIS PROBLEM. I FOUND THIS LEAK WHILE CHANGING MY OIL. :jester:
hi, it was easy to spot the leak,all you have to do is remove 4 bolts and the engine cover comes right and you can see everything.the bolts are 13mm.very easy to do :jester:
hi,it was the complete front diff -unit. the dealer told me mine was the 4 one they did. lots of work.dealer told me the casting was porous,so they leak. the new one is dry,no leaks :banghead:
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
