Programming a remote Key FAB
If the numbers on the back are the same, then it most likely can be programmed---by you. The procedure is rather simple and can be found on the internet. (See next note)
If the numbers on the back are the same, then it most likely can be programmed---by you. If the numbers are not the same I am not sure whether it can or cannot be programmed. However, since you already have it then it would be worth a try. The procedure is rather simple and can be found on the internet.
