IRS Auditor
MoJo
OK, I just found my file of jokes so, you all get to suffer!
A young hotshot gets a job with the IRS. His first assignment is to audit an old Rabbi. He thinks he'll have a little fun with the old Rabbi, so he says, "Rabbi, what do you do with the drippings from the
candle?" The Rabbi says, "We send them to the candle factory, and every once in a while they send us a free candle.
The kid says, "And what do you do with the crumbs from your table?" The Rabbi says, "We send them to the matzoh ball factory, and every once in a while they send us a free box of matzoh balls." The kid says, "And what do you do with the foreskins from your circumcisions?" The Rabbi says, "We send them to the IRS, and every once in a while they send us a little prick like you."
:thumbs:
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,410 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
