Lug Pattern
6 lug on 5 1/2 inch center.
It's preferable that you use "hub centric" wheels on your truck to reduce potential vibration, although a lot of people do not use hub centric without any problems.
what does hub centric mean?
Lug centric wheels can be balanced with the proper adapters...
instead of using a cone, the adapter is a ring with studs that go into the lug holes.
Also, if at all possible, see if you can get your wheel/tires "roadforce" balanced. It's usually more $ than standard speed balancing, but it really helps with vibration issues.
    overspeed
    overspeed
  • Who's Online   4 Members, 0 Anonymous, 309 Guests (See full list)
