2002 496 Specs
their crap. the specs I mean.
Or go to the GM vortec engine web siteMy Webpage
Cam let just say run out of breath at 4200r's
8.1L (8128cc) :thumbs:
Overhead Valves
(2 Valves per cylinder)
4.25"bore x 4.37" stroke :P
9:1:1
fire order 1-8-7-2-6-5-4-3
where made Tonawanda, NY :thumbs:
rods are forged :devil:
crankshaft is nodular iron :sigh:
pistons are weak ass slapping hypertonic
Do you know how to use yahoo and google search engines??? its pretty easy. type what you want to search for. hit enter and select the best selection of your search.
Try this site:
http://www.gm.com/automotive/gmpowertrain/...ews/press16.htm
2003 Vortec HP3 8100 High Performance Crate Engine
Specifications
Type: 8.1L V8
Displacement:  8127 cc (496 cu.in.)
Compression ratio: 9.1:1
Valve Config.: Pushrod actuated overhead canted valves ( 2 valves per cylinder )
Valve Lifters: Hydraulic roller
Firing Order: 1-8-7-2-6-5-4-3
Bore & Stroke: 107.95 x 111.00mm (4.25 x 4.37 in.)
Main Bearing Caps: 4-bolt cast iron
Balance Method: Internal engine balance
Intake Manifold: Factory-installed PFI (equal length runner) manifold
Oil Pan Capacity: 8 qt . (7 quart fill level after system charge)
Fuel Type: Gasoline (unleaded)(87 octane)
Fuel System: Port fuel injection
Horsepower: 525HP @ 5400 RPM
Torque: ( lb-ft ) : 560 lb-ft @ 4000 RPM
Engine Rotation: Clockwise (facing front of engine)
Spark Plugs: Platinum (1.5-mm gap )
Emissions Controls: Internal PCV orifice system
Paint Protection: Component painted
Shipping Weight: 734.14 lb (333 kg)
Materials
Block: Cast iron
Cylinder Head:  Cast iron
Intake Manifold: Coated cast aluminum
Main Bearing Caps: Cast nodular iron
Crankshaft: Cast nodular iron
Camshaft: Steel
Connecting Rods: Forged steel (1141SAE shot-peened and magnafluxed with 9mm diameter bolts)
Pistons: Hypereutectic coated cast aluminum
Manufacturing
Assembly Site: Tonawanda, New York
