What do you do for a living?
Truckman031
FDOT roadway inspector. We are basically babysitters on the job that keeps contractors in line to ensure that they are building the road in compliance with Florida specifications. I love my job and look forward to it every single day.
Bottom line--I'm there to make sure the roads that are built are safe for you and your family to drive upon.
While my true love in life is sleeping late, spending time outside and working on my motorcycle and truck, the way I bring home the bacon is by flying helicopters for the Army. While it ain't as glorious as it may sound, I can't lie... it's fun as hell.
-Ed
I'm in-between jobs right now.
Leaving Hallmark Cards Inc. (Been there for 5 years... Sick of it)
Been interviewing all types of places for 1 week and a half.
Trying to get into the Tow Truck Biz.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
