water spots on windows
A very fine polish compound (something without wax) will get the water spots off. Test it first on a small spot beforehand just in case.
I use Diamondite for my glass and really like it even though it can be a lot of work. It does essentially the same thing as a polish.
You have what you need to clean your windows in the kitchen. I have used it for years on my jetski to remove water spots. Its called vinegar. Since vinegar is a very mild acid, actually it is glacial acetic acid, and the water spots are nothing more than a calcium residue left behind after the water evaporates. The vinegar disolves the calcium and you are left with clean windows. I usually dilute the vinegar with water.
White vinigar is best. Works good. Also, if not to bad, Stoners and newspaper gets mine off. :cool:
You might try using what water softners systems use........salt.  I gotta replace the salt in my water softner every month.  That SOB uses it up.
Salt (NaCl) doesn't remove water spots or actually even soften the water, it just is used to regenerate the media in the water softner (ion exchange) Ca <-> Na so it wont "plug" up.
  • 4 weeks later...
I have hard water and have two proven methods.
1) Barkeepers Friend. It is inexpensive and available in most grocery stores. It comes in a can (gold label) like Comet. It is for Stainless Steel, porcelain, glass, and etc. I saw it on one of the Saturday TV car shows.
I wet my windshield, sprinkle some of the barkeepers friend on a rag and apply it to the windshield and rinse well with plenty of water. I try not to get in on the paint (that's the reason for putting it on the rag) and don't know if it will harm it and don't want to find out the hard way. This stuff works great it removes bugs, road film and for the money my favorite choice.
2) DuraGloss winshield spot remover. available around here at local auto parts stores. Kinda pricey.
    mighty K20
    mighty K20
  • Who's Online   3 Members, 0 Anonymous, 555 Guests (See full list)
