Has anyone used this website
tmf6902
My wife and I got married in the Bahamas last year, and the whole time we drank this beer called Kalik....it was next to impossible to find in FL, now that we moved to NC it is impossible. But I came upon this website tonight
Sendbeer.com
Anyone ever use it??? it's a child site of send.com.....I dunno sounds to good to be true, and I don't want to be ripped off...but I sure would like some Bahamian beer.
I have never heard of it, but there are several sites out there that will ship beer/wine to your door. I've never used one.
Problem is, the gooberment here has decided that I shouldn't be able to utilize this particular type of mail order...Or the "adult" kind for that matter.
I can't mail order beer, wine, or porn anonymously to my door. I have to go out and get caught by all the old ladies that know my mom. :cool:
My point is, of course...Check around, heck...Even email the site and ask if they ship to your state. Apparently there are quite a few states that won't allow it.
yeah, that's a good idea....it is an interesting idea.....if I had only known about it in college, I wouldn't have had to find the "legal" people to buy me beer. Although it's pretty darn expensive....they want $32 bucks for a 12 pack, and $18 for shipping....probably to pay off the UPS guy.....for that much I can drive my truck down to FL, and fill up the bed, and drive back.
Check with a place in VA called the Vintage Cellar, they are located in Blacksburg and Radford. They do ship beer, and that is where i get almost all of my imprts. Although I'm close enough to driver there. However if they have what you want and cannot ship it to you I can pick it up for you and arrange something. Let me know.
