KoolAID Posted October 9, 2004 Posted October 9, 2004 I've ordered a dual 10" sub box from www.subbox.net. I like what they have, and the quality looks good - online anyway. Is anyone running this box? I'm hoping I didn't make a mistake.
mlwabc Posted October 28, 2004 Posted October 28, 2004 I've ordered a dual 10" sub box from www.subbox.net. I like what they have, and the quality looks good - online anyway. Is anyone running this box? I'm hoping I didn't make a mistake. <{POST_SNAPBACK}> I was just wondering if you have installed the new box? I was curious how it worked out.
KoolAID Posted October 30, 2004 Author Posted October 30, 2004 I've ordered a dual 10" sub box from www.subbox.net. I like what they have, and the quality looks good - online anyway. Is anyone running this box? I'm hoping I didn't make a mistake. <{POST_SNAPBACK}> I was just wondering if you have installed the new box? I was curious how it worked out. <{POST_SNAPBACK}> Installing it today! Will let you know how it goes. The first thing I've noticed is that they charge $30 extra for "OEM Color Match" and it does NOT match... More to come. KoolAID
KoolAID Posted October 31, 2004 Author Posted October 31, 2004 I've ordered a dual 10" sub box from www.subbox.net. I like what they have, and the quality looks good - online anyway. Is anyone running this box? I'm hoping I didn't make a mistake. <{POST_SNAPBACK}> I was just wondering if you have installed the new box? I was curious how it worked out. <{POST_SNAPBACK}> Installing it today! Will let you know how it goes. The first thing I've noticed is that they charge $30 extra for "OEM Color Match" and it does NOT match... More to come. KoolAID <{POST_SNAPBACK}> Got it installed tonite. I used 2 JL 10" 10W3V2s and a JL 500/1 amp. I have to say the results are way beyond my expectations. The combination of the components with the box are just fantastic. I was really worried I'd have way too much bass inside the cab with so much power, but the JL amp does a superior job of managing the crossover and amount of bass relative to the type of music. It's incredible. The box is well made, but basic. I had them cut the holes for the JL subs, which are a tiny bit smaller in diameter than their standard hole. The subs fit PERFECTLY in the box. About the only complaint I have is that the box is just a bit big for under the rear seat of my extended cab Sierra Denali. The box I ordered was for a 2004 GMC Sierra, so I figured "close enough". When I say big, I mean that I was hoping the front edge of the box would be slightly underneath the front edge of the bench, when in reality its about flush with the front edge. There is absolutely no room to put anything else under the bench with the SubBox under there. I installed the amp behind the rear bench seat, using a small piece of plywood glued to the rear wall, then screwed the amp into it. KoolAID
