Rubber Floor Mats for Yukon?
Does anyone have a recommendation for a set of rubber floor mats? I'm looking for a set that has a lip to contain liquids and dirt.
-- John
Huskyliners aren't bad. They conform to the floorpan of your vehicle and hold liquids due to a large lip all the way around. Another option would be some of those winter mats with the channels, though most don't have a lip on the edge.
I've had husky liners in my last few trucks, but over time the lips tend to get bent down on the outside. With this truck, I'll try to take them out in the spring and put the factory mats back in.
I have the weathertech mats for the winter in my CTS. (No huskyliners available.) They are much inferior to the huskyliners, allowing water and slush to get past the edges and onto the carpet at the sides.
I thought I saw a set of liners that had a special edge at the door sill. It looked like it allowed the water to flow over the sill. That way it doesn't build up and roll on the carpet somewhere else. Can't remember name.
I have the Husky liners and am pretty happy with them so far. But haven't had a chance to put them through the true test with all the dry weather. Winter is coming and we'll see......
I also have the Husky liners in my '99 Sierra Classic pickup. I like how the rear seat liners (extended cab) cover the center hump. They do a good job at containing snow melt off my shoes in the winter (Colorado).
For whaterver it's worth, I had a set of the Weathertech mats in my '88 BMW 325is. They were also very good at containing dirt, slush and liquids. But after about 6 years and maybe 70K miles, my right heel wore a hole completely through the driver side mat. I've only had the Husky liners in my truck for 8 or 9 months so only time will tell how they hold up.
Regards,
Stephen
Of all the products I've tried I like the Husky trays (not mats) the best. Drivers side coverage and liquid holding is excellent.
But I don't think the Husky's cover enough of the carpet on the passenger side. They do a good job holding liquids and dirt down in the main passenger foot-well area, but riders will naturally want to shift their feet around occasionally, and that means they will sometimes set their left foot up on the middle hump.
I have a 1/2 ton truck with the full center console, so although it's a bit awkward for the rider to put the foot all the way up on the top of the hump, on the little ledge next to the console, there is an intermediate shelf further down that makes a nice footrest. It is a wider hump that’s formed by the rear passenger air conditioning duct set underneath the carpet, which goes under the passenger seat into the back (Extended Cab). The Husky tray does not cover that intermediate shelf, so the carpet started showing lots of dirt there, and even a little wear.
My solution? I recently I bought a different product that is working out great so far. It’s the full, total coverage side-to-side (door-to-door) floor mat from Catch-All. It’s the all-rubber version (no carpeting). It provides a full tray for the driver’s side, goes completely over the center hump – it goes underneath the center console – down the passengers side totally covering all those ledges and shelves, then forming a complete tray in the passenger side foot well. Looks great, and covers everything in both foot wells, as well as all the carpeting on both sides of the center hump.
But it’s not perfect – two problems;
(1) The outer lip of the Catch-All mat isn’t high enough to be as effective at catching liquids as the Husky tray. For that reason, I put my Husky’s right back in, on top of the Catch-All. The fit is real good; even better, I think, that when the Husky’s were in there by themselves. Looks good too – black Husky’s on tan colored Catch-All’s.
(2) While the molded shape of the Catch-All mat is a very good fit in both foot well areas, it simply didn’t seem to be wide enough. That is, the center hump seemed to be ‘relatively’ too tall. If I got a good fit in the drivers side foot well, then the mat wouldn’t extend all the way over to the door on the passenger side. That same problem existed in reverse. Even though I made sure to install the mats on a very warm day, so they were nice and flexible, they still wouldn’t make full coverage.
So I cut the mat right in two, making, in effect, two separate trays out of the one complete unit. There are three little cup-shaped depressions molded into the Catch-All mat where it sits on top of the center hump, and I sliced around those little cups, eliminating them completely. Then I laid in the Catch-All mat (now two pieces), and re-installed the center console. Because of doing that, the mat now fits completely snug all the way over to both doors. The cut is completely below the center console so it doesn’t show and, more to the point, still provides total protection of the carpet in all areas where folks might put their feet.
So that is my solution. Hope this helps.
gnutruk
"But after about 6 years and maybe 70K miles, my right heel wore a hole completely through the driver side mat. I've only had the Husky liners in my truck for 8 or 9 months so only time will tell how they hold up."
Two comments:
(1) WELL FOR HEAVEN'S SAKE TAKE OFF YOUR SPURS BEFORE DRIVING YOUR VEHICLE!! :tear::D:loser::D:bs:
(couldn't resist)
(2) All floor mats get worn through right at that spot. What I've done is I got a small section of ultra-heavy rubber-backed carpet, and affixed it onto my Husky trays using double stick carpet tape. Doesn't slide around, and seems to be holding up so far.
gnutruk
Husky liners are guaranteed so if ya wear em out they will replace them....Well taht's what the warranty card said anyway... :tear:
husky liners, ive been mudding offroading, snow, leaves whatever you want to throw at it, it will hold, the best part about snow is that when it melts it just stays in the mat and you can just dump it out, theyre real easy to clean too, (brush, soap, and a hose)
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 0 Anonymous, 487 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
