Fluid Recycling
tmf6902
When I change my oil I bring it to the autoparts store to recycle.....Do they take gear oil/tranny fluid too?? And what the heck do you do with radiator fluid?
Just curious...
thanks
TMF
If the auto parts store doesnt take it, bring it to a local recycling center you can get rid if it there, same with the filters. There usulally staffed with people doing there community service (been there done that :cool: ) and they unload it all so you dont have to get oil all over you :flag: .
For Calif bay area folks, coolant must be taken to the county hazardous chemical disposal facility. I've been so lazy abou this that I have had 2 gallons of drained coolant in a bottle for over 4 years - and even took it with us when we moved houses. :flag:
I don't know what the story is with trans and gear fluids. I had just thrown it all in with the engine oil. :cool:
Advance Auto takes it here in my part of NC. Just put all oils, ATF, Gear and engine oil together and take it in. As for Antifreeze, have to look in the phone book and call around on that one.
Check out this site it has numbers to call in NC Waste Antifreeze info
:flag:
If the auto parts store doesnt take it, bring it to a local recycling center you can get rid if it there, same with the filters. There usulally staffed with people doing there community service (been there done that :fume: ) and they unload it all so you dont have to get oil all over you  :D .
the guys at my local cnetr are wierd. I'd rather get oil on me that get within 15 feet of some of them. :cool:
Must be an Oklahoma thing! :flag:
Just kidding.
