Off Road A/T and M/T Tires
DustinM
It is that time of year, I need to be thinking about new tires for my tire hog. I am running 315/75/16 Pro Comp M/Ts now and they are okay but I am thinking about getting something else and was wondering what everyone else had and how you liked them as far as noise and wear issues. I am sure this is another repost but I am curious to see...
:mad::D
i'm running yokohama geo lander AT-II i love them they are quiet as long as you rotate them and dont let the cupping start. good in snow and dirt/mud
I have goodyear wrangler mt's, so far I have about 25k miles on them, there is still quite a bit of tread left, but they are loud as hell.....really obnoxious....I think my swampers are more quiet. The do great in the sand. But the noise is my only complaint about them. I roate and balance regularly also.
But I am getting some nitto terra grapplers to replace these....and I'll save these for the sand and snow.
Are the Nitto Grapplers you are getting the new mud terrain or the all terrain?
Between my BFG At and Mt tires I like the MT tires overall. Only thing I havent tested them on is snow
I am gonna go with the all terrain. I've had it for a while with the noise of mud terrain tires. I only go in the sand, so they should be just fine. Atleast that's what I have read and people on here have told me.
My Goodyear MTR's are as quiet as any AT on the market. The older MT's are a different story. When it comes time to replace them I will be putting on another set of MTR's.
I like the Bridgestone Dueler Revos I have on my Jimmy. Nice tread, great wear, no noise. I would advise against MTs in the snow. Big open blocks suck in snow.
Steve
Mud Terrains are normally great in snow, but horrible on ice. I will always have AT's on my trucks here in MN.
Steve
I know with ATVs that sure is the case. Got my Polaris (with Gatorbacks) stucks more than a few times in snow. All it did was dig 4 holes in the snow and left it high centered
Steve
I've never heard of gatorbacks, but they must come stock, right? If you get a real mud tire like outlaws or GBC Gators, they go through the snow really well.
Same goes for a truck tire. The goodyear MTRs get good ratings on snow, but bad for ice and rain. I think AT's are probably better in average snow, but deep snow I would have to say MTs.
On snow and ice the more biting edges the better. I mud tire with big blocky tread is great in mud (open blocks don't fill with mud) but in snow/ice it doesn't have many biting edges. Those big tread blocks are usually smooth. Now I've seen people have their MT's siped (grooves cut on the blocks for more biting edges) and it makes a night and day difference. On snow/ice narrow tires with more biting edges have the advantage.
A guy I worked with had a jacked up truck with huge MTs on it and in snow he could just spin all 4 tires on top the snow and go nowhere. The big tires pretty much just floated on the snow and got no traction.
Steve
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 825 Guests (See full list)
