Just saying hello
dirtywhitehoe98
Hey, ive been searching for a GM truck forum ever since i bought my Tahoe in August...looks like I found a great one. I have a 98 Chevy Tahoe, bought it with 85K on it, its called the dirty white hoe because its hard to keep clean..lol... pictures coming soon. Thanks, im looking forward of being part of this forum.
  • 3 weeks later...
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
