wanted
klwoodie
  • 4 weeks later...
Still looking? I have the MSD-6AL with 6000 RPM limiter module that I took out of a running vehicle a few months ago.
email or PM me if still looking...
    bellssn690
    bellssn690
  • Who's Online   4 Members, 1 Anonymous, 524 Guests (See full list)
