wheel interchange
Anyone know if a mid 80's steel 3/4 ton wheel will fit an 03 2500HD. I don't want to run my alum wheels through an Ohio winter.
Thanks in advance
Yes, 8-lug wheels have had the same back spacing for years. Even all the way back to the good ole straight axle days.
When I lived in salty Michigan I would always see people stash away their regular wheels in the winter to protect them. I never could understand that because aluminum and even steel wheels can handle the salt far much better than body panels, brake components, starter motor, electric 4wd encoder motor and wiring harness can handle the salt-water intrusion and corrosion. But nobody seems worried about the important stuff...only worried about the wheels.
As Andre Agassi once said, "Image is everything" :cheers:
Actually aluminum wheels get damaged in a really bad way with corrosion from road salt. It will pit the aluminum near the bead so bad that you will end up with slow leaks. It gets bad enough that a sealer won't even work. Here in Montreal, Quebec we use more road salt than anywhere else in north america and it's a killer on our vehicles. But I agree that the body is more important to protect and that's why every second year I get my cars lubed inside the panels with a gel lube. Used to use old oil but it's now illegal to do so. The gel doesn't run down like oil and lasts for years. Just my 2 cents.
The best thing I found you can do to preserve a vehicle is keep it clean and keep it in a garage when not driving it.
I have an 83 k20 that has been an Ohio truck all its life and garage kept up until 2 yrs ago. After I started leaving it outside it really stated to rust in all the normal places. It still has all the orig. body panels and is a nice truck.
I use a great rustproofing at our bodyshop for corrosion protection in hard to reach areas. The product is called Transtar amber rustproofing #4423. It comes in an aerosol with a wand (like WD40 wand). I am pretty sure its thinned down version of cosmoline. It will actually creeparound all the spot welds and between the seams. I sprayed it in all the door bottom seams, hood lip, fender bottoms, tailgate bottom, rockers...etc... Just put the wand in any hole and spray. It will only work for inner panels, not dense enough for underside abuse. For the under side I use Rusfree Undercoating, you need a compressor and application gun for it though.
I highly recommend the Transtar if you care about your truck and plan on having it for a long time. Plus you can do it yourself and onceit tacks up it wont run out like cosmoline does in the summer.
    HWN808
    HWN808
  • Who's Online   4 Members, 0 Anonymous, 930 Guests (See full list)
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
