285 or 265
i cant decide between staying w/265's or going to 285's. i do no off-roading, mostly city/highway.   265's of course are cheaper which is good (saving for a big screen tv!). any advise? oh, thinking about going w/ pirelli a/t.
285's look really good, but I love my big screen TV too...  If you go with 285's you may want to get your speedo recalibrated.
Another tire that I have run in the past and thought was great was the Cooper Discoverer AT.  It's a little more aggressive (and slightly noisier) than stock, but get's great traction in snow and rain.
I just got new 285 Brigstones Duleler AT's last week. I have to say it's the best thing I have ever done to my truck. The truck finially rides good since I got rid of those ####$y firestones. As for the speedo, I found it was off my 3 or 4 mph after 70 mph. Meaning when I going 70mph, I was actually going about 73 or 74, not a big deal
I personally would go with some LT rated 265's.  I do agree that the 285's may look a little better, but they are just too wide for my tastes.  If you live in an area where you get alot of snow, you will probably be better off with the narrower tire.  Either way you go, it will be better then the stock tires.   :D
I have 285's (for over 12K miles now) with no lift and no problems
This is a little bit off this topic but I heard that all of the Firestone AT's have been recalled. My 2001 Silverado came with them and the dealer said not to worry. The are not the same as those on the Fords. Anyone heard anything about it? ???
i have a z-71 with 285 BFG A/T's on it and had no problem at all.  the only thing that you might have to do is crank the torsion bars a couple turns (if your front end sits particularly low from the factory).  if you do that, get it aligned.
if you do a search for torsion bars or even for 285's, you'll get lots and lots of information!
that was among my very favorite upgrades.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
