GM 700R4 torque convertor problem
I have a 1996 GMC Z-71 with a 6 inch lift, 35 inch tires. Just had GM put in 4.56 gears. So now RPMS are about stock. Also had a new crate engine put in. Ever since I got truck back, torque convertor goes in lock up sometimes and sometimes not. It almost always with lock up like it is susposed to if I shut truck off and then take off. But a few miles down the road it may not kick in, then all of the sudden it will. I also have a new computer in it, so I know it's not that. Tranny guy says it may be Torque convertor solnoid. Pretty cheap, but want to be sure. Can you all help? Thanks!
Has the new PCM (computer) been calibrated for the mods (gear ratio,taller tires, speedo correction...etc...) may need to plug in a TechII or equivelant and do a "flight check" to see if the PCM is "TELLING' the tranny to lock-up the converter.....just a thought
Make sure the engine coolant temp is at least 180 deg other wise TCC will not be enabled since the PCM thinks the vehicle is cold. :cheers:
There are so many things that it could be. Scanning the truck with most any scanner should tell if there are any codes and if everything is functioning properly. A common one is for the brake switch to fail, even though the brake lights will not be on, the computer sees them as on and stops it from going into lock-up with no codes. Simply try pulling back on the brake pedal. Beyond that there is a diagnostic routine to run through.
well if its a 96 it aint no 700r4 man a 700r4 has like no electronics in it and it would hapen on a 700r4 unless the torque was put in wrong but then it would b messed all the time
True, it would most likely be a 4L60e....but if a 700R4 was swaped in, and the detent cable wasnt adjusted properly, it would'nt go into OD either....just a thought
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,089 Guests (See full list)
