Tire Wheel Consultant Wanted
I realize this has been discussed over and over again, but my ADD is keeping me from pulling all the forum pieces together.
I just bought a new 2004 Chevy 2500HD. I love the truck but am embarrassed by the tires. 245/75/16 - Certainly not "HD". I'd like to go just a little more agressive and larger - like the BFG AT. (265/75/16??) Any size suggestions? The thin stock tires tend to bog down in the mud, which is in excess right now on my property. I've been told wider and more agrressive will help. But will a slightly larger tire affect my truck warrenty? Will they rub? What kind of computer adjustment do I ask for? Will the dealer cooperate? Why does GM insist on the 245's?
The Work Truck package wheels aren't too exciting either. Thinking of American Eagle Series 194 (16x8). Should I wait until after winter to add these? I want my truck to look like this: http://www.aewheel.com/gallery_vehicle.cfm?id=18
Thanks!
Thanks!
First off, try going with an LT tire, not a P-metric tire. A 265-75-16 on my Z71 seems to be a nice size, though the OEM tire is not great off-road. Try a Pirelli Scorpion AT or the BFGs that you mentioned. Another tire to check out, though ONLY in the LT trim (it has a better tread pattern than the P-Metric version, for some reason) is the BFG Rugged Trail or the BFG Land Terrain (These are BFG-made Wal-Mart tires, but VERY similar to the old style of BFG All-Terrain T/A. THye are under $100 each at Wal-Mart and are very good for an LT tire).
Rims are a personal decision- but I like the American Racing Baja...
I have BFG 285/75R 16 All Terrains on the factory wheel, no problems at all. Good clearance, nominal decrease in gas mileage, and my speedo is right on...it may actually be more accurate than it was before. You can see what they look like if you click the link under the picture in my sig.
Nice truck! Thanks for the feedback. What about the warrenty? Will the dealer void my warrenty if I go to a none recommended tire size?
Thanks for the compliment Weeds! As far as the warranty goes, it kinda depends on the dealer and the warranty issue you may have. If you had a speed sensor problem or something like that, the dealer may give you problems. I didn't upsize until I was out of warranty, plus I have friend who is a service writer at my local dealer, which always helps.
    • Oh yes, someone is going to be certainly hitting up GM service/ support for a 20 year old truck.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
