WANTED: 2004 GMC Sierra Bumper with Fog-Lights
I would like to know if anyone would have a used or new bumper from the new 2003-2004 HD's. These bumper's are painted to match the color of the truck. I would like to get ahold of a white one. Please let me know where I can find one. Thank You!
Jeff
I believe the bumper is the same on a HD and non-HD on the 2003-up GMCs. The HDs just have a big gap between the bumper and grille.
May be easier to find one if you look for 1500 too.
Jeff
Why not stay with your own year, and paint your valance by doing some color matching instead? or a maybe a cadaliac conversion?
  • 1 month later...
I have a 2004 factory take off HD front bumper. It is the charcole color paint. It comes with the top chrome bumper, the small plastic clip in the lower valance, the brackets and supports. The paint is in poor condition from being stored in a shed. The chrome also has a slight color variation from sliding across some plywood. I was told it is worth 1400$ from GM new. But i would let it go for a resonable price. I am in southern new hampshire.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
