O & A Freeplay
jcebruin
I had never heard of the Opie and Anthony show before they showed up on XM. They are on a premium channel that I wasn't paying for, but they are free this week. I decided to check them out. I about crashed I was laughing so hard. It's pretty much a guy show, but without the FCC regulations, it's hilarious. Picture SNL with a mix of National Lampoon and the Fword.....
Check it out if you can
Cheers,
J
They used to be on a regular station here (they were based in NY I believe and aired across the coutnry), but then their antics got the attention of the powers that be, and that was that.
