Tailgate cable...
This is weird. I was at the tire shop getting tires on my factory wheels when i went to put one of those tires on the tailgate and the cables that hold the tailgate snapped right in half!! Both sides at the same time! I was like whoa! someone could have gotten hurt if they were sitting on my tailgate or something. Wonder is GM will step in like they did too the full size trucks and recall the cables?
that really sucks man! if i were you, i's contact GM and tell them what happen.... they just might cover it..?
-J's 92
My son's '02 S-10 is at the dealer now and when asked about tailgate cables, they said GM is still evaluating whether to extend the recall to S-10s.
yeah, i'd say its an issue... someone could sit on it, cable snaps they hit there head on somethin... LAWSUIT! LOL
-Joe
