colorado/canyon skid plate
i have a replacement front skid done for the Canyon and Colorado for those who dont like the plastic one they got on there truck from the factory :jester:
heres a pic installed of the plate from a memeber off colorado fans.com
email me if your interested
[email protected]
there available in .188 aluminum or anything else you would like.
Still doesn't protect the front dif. or oil pan.. Not impuning your work but their is a lot left to be done to protect the underside of this model truck.
its only the front skid dude its not supposed to
the others are coming i only got so much time :smash: to come up with designs for the trucks. the others will be complete by january.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
