Pinging is going away...
The pinging that I was having trouble with (5.3 L) and I mentioned in PUT.com seems to be going away...  The truck is now a little over 4 months old and has 1500 miles on it.  After the first 600 - 700 miles I started using the throttle more aggressively...  winding the shift points out to around 2300 - 2500 RPM.  Maybe it's true that there were carbon deposits forming and that this motor wants and needs to stretch it's legs.  It's a running SOB!!!  Much nicer than the 5.4 Triton I traded in!!!
Did you do anything else like maybe change brand or grade of gas you were using?Are you still running your break in oil?If not,did changing it seem to quiet your noise?
Just curious.
All I did was stop babying it so much...  I drive alot of short trips and never really ran the truck hard.  Don't get me wrong, because I'm not driving it like I'm at the drag strip, but I stay neck in neck with the car beside when the light turns green, if not a little in front.
I've been running either Agway or Sheetz fuel (Sheetz is a convenient store in the Eastern States for those who don't know that).
I have 1600 miles on it now and since the weather has gotten cold the 2nd gear cold shift extender (it doesn't shift into third until almost 35 mph) is working almost everyday.  This feature hangs in there until I'm showing about 180 on the temp gauge.
I'm lead to believe that this pinging may actually be a carbon buildup as everyone says, and it is caused by 2 things...  Aluminum heads, and high compression.
With the slightly higher RPM's I think I'm keeping the head temps up where they need to be.
Ya know Shaners, I had the exact same problem. I started hammering on it more and the pinging went away. Lately I have been babying it again(with the cold weather and all), and now the ping came back. They say that the 5.3 is a high and fast reving engine, so I guess a guy has to step on the throttle a little and not worry about it. I guess there is not much to worry about anyhow....it's not a Triton.....it's a VORTEC!
My truck is in the shop as we speak and one of the things I'm going to have them do is reprogram the tranny.  This should keep the RPM's up a little higher and should also help keep the "pings" away.  (I hope)
You guys dont need to baby your new truck,its the worst thing for it,run it up thru the grears,using the full power range,just keep it out of redline and dont sustain high rpm'sShort bursts of power,then letting off are the best way to seat your rings and let off pulls oil past them,keeping them well lubed duringbreakin.Vary speed a lot too,no highway driving-its the worst.Ive found that new trucks that are run and allowed to stretch there legs,seem to last the longest and run the best.Im just jealous that you have an ew truck to break in,mine are well broken in now.
  • 6 years later...
    ballencd
    ballencd
  • Who's Online   5 Members, 1 Anonymous, 654 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
