Got my new treads
Well after 31,000 miles the BFG AT's are about 97% done for and had to go shopping tonight. After about 20 minutes of trying to decide I opted for the Kelly Safari MSR's so now getting in and out of camp this winter should be easy. I know it's late now but has anyone had any experience with the Kelly MSR ? I've had the AWR's and they were a pretty good tire but never had these before.
You must have got a bad set of tires......I have almost 60k on my bfg at's now and should get 70k out of them before i feel they need to be replaced. But if you normaly get 30k out of your tires I would stick to the less expensive brands. I have never had Kelly tires so don't know too much about them.
I've currently got a little over 30k on my BFG's. I've got some abnormal tire wear going on that the alignment shop and I are working on. As a result, two of my tires are pretty good with 40-50% tread left but the other two worn on the insides. I don't know how long they will last but I'm hoping for at least another 15-20k or more. We'll see.
I had the kelley's on the work truck--lasted about 28,000 miles....50% highway 50% off-road construction sites
I have another set on there now they're the AWR's.
either way it's a good el-cheapo tire
Alot of people around here run Kelly tires. I think they are a pretty decent tire, but I've never run them before.
Most people I know run the AWR's but I know a guy at work that has the MSR's on his F150. They are a very aggressive tire and go great, but I don't think they are a high mileage tire..
Do you guys do burnout contests on the weekends?
I've got over 100,000km on the Michelin LTX's which is about 62,000miles and they've got 3/32 above the wear bars. In other words, they still look great. They should go another 40-50,000km. Maybe two years or so...
They are 265/75R16's and I rotate them every 10,000km
Unfortunately mine came with the Goodyears, lousy traction in the rain. Problem is I only have 16K on them and can’t justify buying new tires.
Mine came with the Goodyears too and I had no problem justifying getting new tires! I just had my wife drive the truck in the rain and that pretty much settled that :thumbs: I put the BFG's on at 7k miles on the truck and I went up to 285's - the best thing I've done to my truck so far - they look better and drive better in all conditions. It was an easy choice for me. :)
I got 41k out of a set of BFG AT KO 295/75r16's. I plan to be buying 285/75r16's for my new HD.
KirkRHughes, I learned to drive in a '78 Pinto SE w/the 2.3 Liter OHC 4-Cylinder and 4 speed manual tranny. I didn't think any were left on the road.
I got over 65,000 miles out of my 295/75/16 BFG AT's. Had them on 2 different trucks. Getting 30k out of a set tells me something is really wrong. I'm not really easy on tires either!?! Lots of rough 4 wheeling in rocks and towing a 21 foot ski boat every weekend.
Rick
I have about 25,000 on my BFG A/T's, and there is still 7/32" left! I actually bought them when I had my Ram, and when I traded it in on the Sierra, I realized that the GMC had the same size tires (265-70-17) so I had the dealer swap my BFG's for the crappy Goodyears that the GMC comes with.
I realize that you were asking about the tires you bought, and not about how long everyone else's BFG's are lasting. I don't have any experience with the tires you bought, but I guess the only important thing is that you like them!
They look like they have a decent aggressive tread that will work well in the snow, if we ever get any. How do you like the way they handle in the rain?
    Bulldogger
    Bulldogger
  • Who's Online   5 Members, 1 Anonymous, 841 Guests (See full list)
    • It added a cost layer to an already limited production supply. True that.
    • Swap costs and supply/demand balance. When a barrel comes out of the ground the entire range of products are present but not all at the same percentage.    Breakdown of Refined Products The following table summarizes the approximate output from a standard 42-gallon barrel of crude oil: Product Type Gallons per Barrel Percentage of Total Gasoline 20 gallons 45% Diesel Fuel 9 gallons 21% Other Products 13 gallons 31%   Most of that diesel figure is 'straight run' or cut from the barrel. Gasoline 'cut from the barrel runs 0 to 20% at the crude. So in the crude unit there is more diesel the gasoline, usually.  The full refining experience however gives the tabled values. Ego there is half the diesel than gasoline after the 'first crack' That could be an FCC unit, or Isomax or....   Those units take heavy products and break the big ones into little ones. Those numbers are harder to get hold of but directionally it ends up the same.    Really light products are very profitable. Ethylene and Propylene to name two. Those are cracked from slightly heavier feeds like NG and Propane and Ethane. The cracker harshness determines the feed for distillation. Those feeds come from less profitable products like diesel and gasoline.    So...there is a swap cost. How much market is there TODAY and what crude am I running TODAY..... what is my process capable of always.    There is this as well. The USA uses allot more gasoline than it does diesel so in the cracker the process is tilted to gasoline production which....limits supply of diesel. OTR uses the most and it has different requirements than automotive and agricultural.  Limiting auto products.    You are correct however. It is less refined, just less of it. Allot less.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
    • Question for you Grumpy, why is diesel so much more than gasoline? Seems to me that it may be slightly a little less refined than gas and it doesn't have 10% alcohol which presumably lowers the price of gas
