245 to 265 gas mileage ?
245/265...Those numbers are referring the width of the tire.
You would have to post the entire tire (say that three times fast) size to be sure, as the second number is the height/width ratio.
But if you are talking about going to a taller tire, it will hurt your torque, therefore your towing.
You mileage may be slightly better on long haul, but the motor would lug at lower RPMs. This would negatively affect gas mileage in town, and when towing. Basically, it's raising your final drive ratio...Just like putting taller gears in would do.
Nothing too bad, because you aren't talking about a HUGE change, but you will be able to notice the difference.
This can be remedied by changing out the gears (optimal, but expensive)...Or by getting your PCM re-tuned, which is a lot cheaper, but not quite as effective.
Keep in mind that your speedometer/odometer will be off a bit as well.
Welcome to the forums, by the way :wtf:
my BAD  245/75/16    Thanks
I went from 245 75 r16 to 265 75 r 16. the taller the tire, the less low end you have. If you have the 4.10 rear end , it will not really be 4.10 after you go to 265. You wont gain anything other than a fuller wheel well and about and half andinch to and inch in ride height.
While we are on this topic (and some knowledge is speaking) I want to switch tires and wheels.
Stock is LT 245/75 R 16.
The new wheels I want are 17". The only tires in the load range "E" that I can find are LT 265/75 R 17 and 265/70 R 17. I don't want to switch to a taller tire, so would the 265/70 R 17 suit me better? Or is it a taller tire?
Thanks,
Ben
Oh, and how much mileage would I lose going to the wider tires?
Thanks,
Ben
Here is a little formula to convert from metric size to english:
The first number is your width, the second number is the % of the width measured from the edge of the rim to the outside perimeter(tire radius-wheel radius) of the tire. Example:
1. convert from mm to cm 265/10=26.5
2. convert from cm to inches 26.5/(2.54)=10.43 This number is you width.
3. multiply the percentage by the width: 10.43*.70=7.30
4. multiply that result by 2(converts radius to diameter): 7.30*2=14.6
5. add the diameter of the wheel to this number: 14.6+17=31.6
So, if you are running 265/70 R17, your approximate tire size in inches is:
31.6 X 10.43. Use this formula for 245/75 R16's and your tire size is:30.47 X 9.65
You are gaining about 1 inch in heighth and about 7/8 in width. Hope this helps.
Holy crap, that is very useful! :wtf: Tab's on me! Nice truck, too #9.
That will help quite a bit in my search for the perfect tire/wheel combo.
Btw, I am looking at the Cragar Black Soft wheels (pc'd black steel) with A/T tires that carry the E load range, so it is kinda hard to find the appropriate sizes. It seems as if there are zero 245/75R17's out there. Oh well, the search continues.
Edit: Actually, I overlooked something. The tires I just mentioned un 32.65" tall according to your excel file. The stockers are 31.65". I didn't take into consideration the proportional ratio of wheel diameter to tire diameter. An additional inch of diameter (about 3.14" greater in circumference) shouldn't make that big of a difference, should it?----Just found a way to figure this out.
This should work:
(New Tire Diameter / Original Tire Diameter) X Indicated Speed = Actual Speed with new tires
Example:
(32.5" / 27") X 55MPH = 66.2 MPH Actual Speed with new tires
My change from a 31.65" to a 32.65" tire increases the speed from 55mph to 56.737mph. I can probably live with a difference as little as 2mph. I can just factor that into my usual speeding habits.
Thanks,
Ben
I f I put 265 on will my mileage go up or down?
04 2500HD with a 6.0  truck is a stock
Will it help me with pulling my race car?
1Bad - I have the 265's on my truck and didnt notice much of a gas change - if any at all. As for pulling yuor race car - if you have 4.10's - you will barely notice the difference. My truck revs about 200 rpms lower at 75 now.
Remember - if you change your size - you will need to reprogram your speedo - so it reads correctly (if you want) - This is a perfect time to convince yourself to get a Westers tune....not only will you fix your speedo - but you will get more HP/TQ and gas milage to boot !!!!
Sorry for the plug !!! I love my Westers !!!
Yup yup....I agree.
I went from 265/75/r16 to 315/70/r17's and it definitely impacted gas mileage and low end torque/speed. My new PCM is on the way (mainly for the speedo calibration) but hey, while you're doing it you may as well get some extra ponies too right?
Anywho...I'm headed to the outerbanks this weekend so I'm hoping to have my new PCM in by then so I can see how it does.
If you are worried about gas mileage, buy a car. My 8.1 / Allison sucks gas like no other, but its a big engine in a truck. I have 285/70/17's on it and didn't notice a difference probably because it was so bad to begin with. Oh well. I average about 9.5 normally and around 5 pulling my 12,300 pound boat. Thats why you always take customers (and/or your friends) out on the boat so the gas bill goes to your business and comes right off your corporate taxes!!
Good luck with the tires. Bigger tires will make it look much better. :cheers:
Getting a little info from the Tire Rack on tire diameters we can assume the following.
According to Tirerack.com the BF Goodrick Radial Long Trail 245 has a diameter of 30.5 inches and the 285 has a diameter of 32.8 or a 7.5% increase in diameter. That means your "effective" rear gear ratio has been decreased by 7.5% and is now the equivalent of 3.79 approximately. That would net you an increase in fuel efficency.
However your odometer and speedometer are now also off by 7.5%. Each revolution of your larger tire now carries you 7.5% further but your speedometer and odometer are registering less by 7.5% When you attempt to calculate your mpg after driving 100 miles per your odometer your will actually have driven 107.5 miles.
For simplicity's sake lets say you used exactly 10 gallons and using the mileage as indicated by the odometer you will calculate your mpg at 10. In reality your mpg is 10.75 because you really drove 107.5 miles instead of 100 on the 10 gallons of fuel.
Nothing to it.
Get your speedometer re-calibrated after you get new tires and calculating your mpg will once again be simple.
Just noticed we were supposed to be talking about 245's versus 265's not 285's. The difference between those two sizes is only about 1.6% so if you want to see the difference just replace 7.5% with 1.6%. Sorry for the confusion!
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
