Baer Brake upgrades
Here is something you don't see to often. A price decrease from the manufacturer! That means we are able to lower our regular prices even more. This covers some of their Eradispeed rotors along with the Alumasport packages.
Eradispeed +1
Baer Brake Systems, the leader in automotive braking systems is proud to announce the introduction of the EradiSpeed+1 upsized rotor package for the latest generation of GM ½ ton truck and SUV applications. These performance rotors feature LITE™ (Low Inertia / Thermally Efficient) technology. Two piece rotors have anodized billet aluminum hats with re-useable stainless N.A.S. aircraft hardware. Designed specifically for use with popular 18-22-inch wheels, EradiSpeed+1's feature massive 14" diameter rotors front and rear, along with all the custom hardware to make installation quick and easy. EradiSpeed+1 rotors are also "cosmetically enhanced" with cross-drilled, slotted and zinc washed surfaces.
Cast from a high friction iron alloy, EradiSpeed+1 rotors are designed with more mass for heat absorption, are directionally ventilated for increased pumping efficiency and feature billet or forged aluminum centers, which reduce overall rotor weight. By eliminating the weight at the center of the stock iron rotor, Baer is able to cast the rotor with more mass in the "fire path," (where the pads contact the rotor,) allowing substantially more heat to be absorbed into the rotor. Balancing and heat-treating, coupled with the increased pumping efficiency of directional vanes (vents), ensure that EradiSpeed+1 rotors deliver substantial performance benefits.
Many of today's vehicles using larger wheels experience drastic reductions in braking ability due to the additional weight of the wheel...sometimes up to 35 pounds per wheel. With its larger rotor size, EradiSpeed+1 rotors are able to regain even more than the original braking performance. Best of all there is no need to bleed the system after installation.
Alumasport
Baer's Alumasport brake packages include 2 piece 14" crossdrilled, slotted and zinc washed rotors up front and 1 piece in the rear, red 2 piston PBR calipers all around along with all necessary hardware for the install. These fit all GM 1/2 ton GM trucks and SUVs.
More info and pricing can be seen in the Truck Brakes section of our website!
Yes, they are the new regular pricing. No sales for these right now but there might be something coming up soon (next week :wtf: ).
Yes, they are the new regular pricing. No sales for these right now but there might be something coming up soon (next week :D ).
Keep me posted...I'm looking to upgrade my brakes by the spring. :cheers:
