Only in Oklahoma
facn8me
I love this state.
OKLAHOMA CITY - A state senator has a plan for saving Oklahoma's gamefowl industry now that cockfighters are legally prohibited from pitting birds fitted with razor-like spurs
State Sen. Frank Shurden, a longtime defender of cockfighting, is suggesting that roosters be given little boxing gloves so they can fight without bloodshed. The proposal is in a bill the Democrat has introduced for the legislative session that begins Feb. 7.
I love this state.
I like how the news calls this as an attept to save the Gamefowl industry. Its like these roosters are jobless, and unemployed because they took out cockfighting. :wtf:
Anyway no one I know here in Ok cares for it.
Well I was in Poteau Oklahoma over thanksgiving and was filling up the 2002 EC Z-71 and as I was paying a lady walked in and said "this was out in the parking lot" and proceeds to place a bag of "weed" on the counter. I said the same thing, Only in Oklahoma.
yeah, facn8, did you see the sketches of the equpiment? they will also have senors to score hits, and vests to protect from blows....not word yet on helmets for facemasks
I can't belive we are talking about this.......this state. :wtf:
    Gkistler
    Gkistler
  • Who's Online   2 Members, 0 Anonymous, 893 Guests (See full list)
