Buick HVAC blower motor r/r
nimmer
I know this is not the site to discuss Buick issues, but I need your help. Does anyone know how to r/r the HVAC blower motor on a 1994 Buick Skylark? Or can anyone direct me to a 'forum' that might provide that information? I am a GMC truck owner and visit/contribute to this site and it has been extremely helpful in the past, that's the only reason for starting my research about a Buick here.
Many thanks for any input you might provide.
Thanks
