Avalanche not keeping time
Every time I get in my truck I have to re-set my clock! I know people were talking about the display "flickering" but do I have a possible "power" problem? Wonder if my battery rundown system is "taking-over" my truck?
Anyone have a similiar problem?
Thanks
Brad
I'd say check your battery connections to make sure they are on there all the way.  I believe you need a 7mm socket and a 1/4" ratchet fits back there nicely.  If those are good pull out your radio and check the back for loose wires.  It may just be a loose wire.  If that doesn't work take it to the dealer, might as well use the warranty
I read of a guy having this same problem on his 2500HD on another forum awhile back.  I will try and find it for you (it had a TSB I believe), but the only way to correct it is to have the dealer replace your radio.
