Maricopa County Sheriff
COSilver
Don't know if this is true or not, as I don't live in Arizona, but someone sent this to me - If it is true, then Joe is a hero in my book!
TO THOSE OF YOU NOT FAMILIAR WITH JOE ARPAIO
HE IS THE MARICOPA ARIZONA COUNTY SHERIFF
AND HE KEEPS GETTING ELECTED OVER AND OVER.
THIS IS ONE OF THE REASONS WHY:
Sheriff Joe Arpaio (in Arizona) who created the "tent city jail":
He has jail meals down to 40 cents a serving and charges the inmates for them.
He stopped smoking and porno magazines in the jails. Took away their weights. Cut off all but "G" movies.
He started chain gangs so the inmates could do free work on county and city projects.
Then he started chain gangs for women so he wouldn't get sued for discrimination.
He took away cable TV until he found out there was a federal court order that required cable TV for jails. So he hooked up the cable TV again only let in the Disney channel and the weather channel. When asked why the weather channel he replied, so they will know how hot it's gonna be while they are working on my chain gangs.
He cut off coffee since it has zero nutritional value. When the inmates complained, he told them, "This isn't the Ritz/Carlton. If you don't like it, don't come back."
He bought Newt Gingrich' lecture series on videotape that he pipes into the jails.
When asked by a reporter if he had any lecture series by a Democrat, he replied that a democratic lecture series might explain why a lot of the inmates were in his jails in the first place.
More on the Arizona Sheriff:
With temperatures being even hotter than usual in Phoenix (116 degrees just set a new record), the Associated Press reports: About 2,000 inmates living in a barbed-wire-surrounded tent encampment at the Maricopa County Jail have been given permission to strip down to their government-issued pink boxer shorts.
On Wednesday, hundreds of men wearing boxers were either curled up on their bunk beds or chatted in the tents, which reached 138 degrees inside the week before.
Many were also swathed in wet, pink towels as sweat collected on their chests and dripped down to their pink socks.
"It feels like we are in a furnace," said James Zanzot, an inmate who has lived in the tents for 1 = years. "It's inhumane."
Joe Arpaio, the tough-guy sheriff who created the tent city and long ago started making his prisoners wear pink, and eat bologna sandwiches, is not one bit sympathetic He said Wednesday that he told all of the inmates: "It's 120 degrees in Iraq and our soldiers are living in tents too, and they have to wear full battle gear, but they didn't commit any crimes, so shut your damned mouths!"
There are still a few folks in charge with the right attitude :cheers:
I am from Arizona and Joe is a great guy. The pink boxers the inmates wear were popularizd by Joe and you could, for a while, buy some "Official" Prison boxers with a silk screen of Sherrif Joe's signature on them. I am proud to say that I have a pair. Also, I am not sure how old that article is, but I know the record in Phoenix is about 124 degrees and not 116...as if it wasn't hot enough!
This country could use a whole lot more people in law enforcement that think like Joe. I don't detect a bleeding heart in him! :sigh: I like the idea of using prisoners to clean the roads and do work like that. That should be part of the penalty. Make 'em do something useful. Sherriff Joe has my vote :cheers: Mike
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
