Amazing USMC Sniper
OnBelay
“I’ve learned a few lessons in life that I think helped me along the way,” said Reichert. “Never quit, no matter how tough life can get.” :cheers:
    zibzer2
    zibzer2
  • Who's Online   5 Members, 0 Anonymous, 839 Guests (See full list)
