More music that I am looking for..
General Lee 01
Alright, let's treck back to '95-'97-ish. There were 2 Rock/Alternative songs getting quite alot of radio play, but have since fallen into the "Radio Graveyard" if you will.
One of the local Radio Stations here does a '90s flashback hour these days, and played them in recent weeks. I'm trying to find them.....
The First one, The main "Chorus" is "She thinks she's on the train to mars, she's out back counting stars."
The second one, goes like this, "I think you're smart, you sweet thing. Tell me your name, I'm dying here, ah Whooooooooooo-hooooooooo Got you where I want you."
Can yall help?
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
