Anyone wanna help an Old Lady?
asilverblazer
Well me being the nice grandson I am...
I'm looking into a few issues her car has, 96 Chevy Malibu LS Automatic, not sure on the engine. When you are driving straight or turning right there is an awful growling noise. It goes away when turning left. It is solely dependent on speed. So I think somewhere down the lines of between the hub to transmission. I don't know anything about the car only trucks so any advice is appreciated.
Also it isn't running right (I haven't looked into this yet just going from how she describes it.) I am going to get the code read for more info. Does anyone know some good car forums that might be more able to help? I found some Malibu forums but for older styles not the new Granny cars.
Thanks again.
the noise sounds like a hub bearing, a DIY job if you are competent. Jack up the both front tires and put it in drive, put your hand on the coil sping and you can feel the bad bearing on the bad side.
