Attn: Engine buffs
I have a stock 350 vortec with 4 bolt mains. Out of a 97 3/4 ton.
I am told that the 3/4 ton 350 vortec's had more restrictive heads than the 1/2 ton version. Sooo, I just happen to have a set of new 305 vortec heads laying around. What advantage/disadvantage would putting those heads on my 350 have?
Thanks
the 305 were designed fro a 3.735 bore make vlv is 1.94 intake and the exhaust 1.5. the 350 heads are designed for 4" bore and are common imporments are cut to 2.02 and 1.60 and ported. the 305 head run only a 58cc combustion chamber while the 350/400 head have 64, 76cc chambers. most common on truck are the 76cc heads. u can also use pre 87 head on that block ie 86 and earlier. in 87 the change the suface were the intake and heads meat as wellas the angle the bolts go in the heads. they make vortec manifold that will run carbs if u want to rid ur pcm. ur compresion will be raised from 8.75 to around 9.5-10.5. mainly 92 octane good low end torque lousey top end above 3500rpm. the heads cant surpport the air flow need. rocker arms are interchangable make sure the vlv cover bolts are in the location. if your looking for more power you can pick up a vortec head assembled for 520 a pair from summitracing gmpp parts ccast iron heads. edelbrock amke emision legal head bout 1100 a pair aluminum all assembled.world product also make the head for 87 up engined offers s/r torquer at 400 a peice 50 state legal
hope this help
wildman
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
