New Member from Washington State
Big Red 2500
Been lurkin for a couple days, looking for answers to some questions. I love the site!
Love my 2004 Silverado 2500HD LS 6.0L, CC, 8' Bed
Big Red, Dempsey and Maximus
Eastern Washington here too! East Wenatchee to be exact. :seeya:
Right On! So, I am in the market for Cooper Discoverer S/T 285/75R16 tires. The stock "sausage" BFG 245's gotta go!
You Washington guys know any Cooper dealers that you like? That have good prices?
Thanks,
-Pete
Eastern Washington here too! East Wenatchee to be exact. :D
Thanks,
-Pete
Issaquah Tire.
    zibzer2
    zibzer2
  • Who's Online   6 Members, 0 Anonymous, 806 Guests (See full list)
