Tahoe Power Window Repairs
Something in my '01 Tahoe's driver's window operating mechanism let go when the window froze this winter. The motor runs, but the window does not go either up or down. There is a slight grinding noise when the motor runs, almost like abrasion on glass.
Any ideas what might be wrong and is it easily repairable?
I can't begin to see how to get the interior door trim off to take a look. :D
Window regulator. Unlike the "old days" when they were these huge steel arms and gears, they're now cables and not much else. These tend to break.
Can I fix it or does that need to be a dealer repair?
Can't answer that without knowing your mechanical ability. :D It's not difficult.
Fairly amount of backyard mechanical experience, not body related though.
Is there any involvement with glass alignment?
Once I get the interior upholstery panel off, is there reasonable access to get at things?
Here's the complete procedure directly from our service information. Sorry the pictures don't carry over. This saves me typing in the explanation. :D
Window Regulator Replacement
Removal Procedure
Raise and support the window.
Remove the trim panel. Refer to Trim Panel Replacement - Side Front Door .
Remove the water deflector. Refer to Water Deflector Replacement - Front Door .
Disconnect the wiring harness from the window motor assembly.
Remove the 2 bolts holding the window to the regulator.
Remove the bolts from the window regulator.
Remove the window regulator assembly from the door folding both sides together.
Installation Procedure
Install the regulator to the door.
Install the bolts to the window regulator.
Tighten
Tighten the bolts to 9 N·m (80 lb in).
Align the window to the regulator and install the bolts holding the window to the regulator.
Tighten
Connect the wiring harness to the window motor assembly.
Install the water deflector. Refer to Water Deflector Replacement - Front Door .
Install the trim panel. Refer to Trim Panel Replacement - Side Front Door .
Lower the window. Inspect the window operation.
it's pretty simple repair, i've done it three times now. The only difficult part that i would caution on, is removal of the door panel. be careful, don't force anything... plastic breaks easy.
i would HIGHLY recommend this company Your Part Store on eBay
see if they have the exact one you need. it's probably the same as mine. i recommend them because pricing is low, quality is high, communication is excellent. I had one of mine break after install, they replaced it NO QUESTIONS asked!!!
I think dealer repair is $300 range, do it yourself $60-ish.
GL
Dustin,
3 Times!!
You're not giving me a good feeling about the future of my Tahoe.
Thanks for the reply.
Overall it sounds like something I am going to try.
Can't make it any worse.
Thanks GM Tech.
My windows on 04 Yukon won't operate when freezing temps. Any solution, TSB etc?
Thats exactly when mine failed; froxen windows.
The underlying cause that I discovered is that the cables were rusty and failed.
Got it all apart as previously described by others; not difficult at all.
    250.3k
    Wasierra1500
    Wasierra1500
  • Who's Online   6 Members, 0 Anonymous, 656 Guests (See full list)
