Installing chrome mirror inserts
SteveSierra
GMtech,
I have an 05 Sierra Z71.
I have some chrome mirror inserts that I am using to replace the factory black ones. I notice there are 4 clips(?) and 4 pieces of tape on each insert.
What would be the best way to take off the black ones? Just gently pry around the whole insert until it pops off? Should I be alarmed if the 4 plastic clips break off? The part where they attach on the mirror shouldn't break off right?
Thank you! :happysad:
Steve
Sorry Steve, I don't do any trim type work and haven't a clue. Our trim guy is out until Monday, or I'd ask him. If you can wait until then, or I can find an old mirror to experiment with, I'll get you the answer.
I might be able to offer some help on this. Basically, you just pry until it comes off. The 3M tape is fairly tough but will eventually give. I pry with a butter knife. Yup, a butter knife. It is wider than a screwdriver and can enter further past the mirror cover than just the fingers. I just keep lifting up, walk the knife around a bit, then pry some more. Common sense will take hold after you see how the cover starts coming off. The 3M tape losing adhesion is a bit noisy and sorta worried me a bit when I first did this.
Breaking the plastic tabs is no real big deal since they are mainly just guides and offer little holding ability. The 3M tape is what really holds the mirror covers on. You'll fnd the carcass of old 3M tape on the mirror's body. Some of the tape might still be good and you can leave it there. Other pieces might have months worth of dust-grime and needs to be pulled out. Don't use any adhesion remover since you need good surface for the new tape to stick to.
If your replacement mirror caps did not come with tape already affixed, but go to a hardware store and purchase a small amount and you'll be set.
Anyway, this has been my observation.
Yup! :fume: I did this last night. Decided to take the plunge. I remembered JPCustoms(where I got the inserts - MightyHD, btw-good business, I got the inserts and billet grille in about a week) said to use something like a soft bladed knife(used a butterknife) and just broke the tabs holding the black ones on. The chrome ones came with 4 pieces of sticky tape already attached to the inserts.
Sorry I don't have any pics yet. I just did it late last night, and am now at work. After work I might be able to take a couple of pictures and post them.
I like them because I have the chrome step bars and chrome trim molding. They accent against the carbon paint very well in my opinion.
I'm just waiting to get up the nerve to cut the factory grille to install the billet grille. It isn't a bolt over grille, I didn't see any of those available for my truck.:happysad:
Can you get pics of how you do it?
Where'd you get the chrome inserts?  I'm interested as well!!!!
Thanks!
Mighty HD - on mine, the bottom edge was open enough to slip the butterknife
in there, then I gently pulled the knife upwards near one of the tabs, snapped it,
then just pried off the rest of it with my fingers.
I got them from JPCustoms, one of the vendors here. I see that you have a carbon metallic truck. I think it definately accents that color well with the other chrome on the truck. Good luck! Any questions, just let me know :happysad:
Oh yeah, I put some masking tape on the lower edge, just under the insert when I used the knife, just in case. Didn't want to scratch that up.
  • 2 years later...
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
